Hi all,
My question is about powering Switch Machines and decoders. Whether its better to run them off the DCC Bus, or create a separate Accessory Bus & how to best go about that. Here are the details of my layout:
I just set up my first DCC system (NCE Power Pro 5 amp) it is currently powering about 150 feet of track with 16 turnouts which I plan to automate. Long term I plan on running a total of 6-8 trains on the layout.
Currently my 16 turnouts are totally non-automated. I am strongly leaning towards Tortoise Switch machines. So assuming I go with Toroise, I will need (2) of the NCE 524136 Accessory decoder which can control up to 8 Tortoise switches each. I've choosen not to build a toggle switch panels yet, but to run the switches using the NCE CAB and its Macros.
I understand how each accessory decoder gets connected to a switch machine, and the CAB can then control that switch via the accessory's address in the system.
Should I use my 5 amps DCC bus to power the Tortoise Switch machines AND the decoders, or should I run a separate Bus to power the switches? And if I run a separate accessory Bus, can I use my old MRC Railpower 1370 power supply to power it? It features 18va and an AC output for accessories. Or am I better off buying an Accessory specific power supply? Is there one? What brand and model should I consider? I could buy another NCE P515 5 amp power supply for my accessory Bus right?
