Necrosaro420
What would you guys recommend as far as a powerpack goes for wiring up turnout switches etc? Just a cheapo? Its on a 4x8 layout so dont need to much power, would prefer osmething cheap. Thanks!
terminal block
Use the AC terminals for the switch machines, you get a little more kick, don't really have to worry about current draw as it's instantaneous...run the wires to a terminal block, radio shack has them, then pick up from there to the actuator buttons.
Use the DC output for the lights so you can dim them...unless you have a LOT of lights, you'll be fine with something small.
Dick
Another great option and what I am using on my 4X8 is an old laptop power supply. Any power supply will do, as long as the voltage and amperage is right. I got very lucky and had a 12V 5Amp power supply (power brick) from god knows where, I mounted it under my benchwork and ran the leads to terminal strips. I am running 10 turnouts and about 30 or 40 small lights off it so far and I'm not even putting a dent in it.
Hope this helps.
