I have 2 SD40-2's one has the newer frame mount by the couplers and hex drive but is not the newer rtr series. the other is an older model year that had the four pins securing the shell to the frame . On the older one I removed the pins and used the cast metal buffer plates and added a styrene block to it is now mounted by the couplers .
I wanted to shorten the fuel tank to the 16 feet but see that if I do this there will not much frame left so the frame may break .
I thought I could get a later rtr frame but don't know it that will work with the older BB trucks and I don't see any photo's of that frame or trucks .
I already changed the 88" short hood to 81" on the older model .
Does anyone know if I did find the newer rtr frame if the old trucks would fit .
I thought maybe if I either made the tank 16' 6" the frame may be strong enough and if not make 2 U shaped brackets that would screw mount from the bottom of the frame and just fit inside the shell so each bracket would clear the flywheels sort of a version PK2 used as a weight. I would use the U brackets to add strength to the BB frame .
I can't afford a new or used RTR SD40-2 .
