old track layout HELP
cman1960
Does anyone know of the track list for this layout ? I've searched with no luck. I would like to build this one as it fits my criteria perfect, and I've been looking at a lot of plans. Thanks for any help, Chris.
Interesting track plan I like it!
One thing I might change for operations as well as cost saving is ditch the double crossover tho.
Sunset Limited hasn't been around for a few years, you might have to draw it out in Xtrkcad to figure it out.
Thought I dug pretty deep but found nothing…. Looks fairly straightforward, time to start mucking around on a layout design site, have some fun with it 😉
Does anyone know of the track list for this layout ? I've searched with no luck..
It says it is Kato Unitrack. They don't make that many pieces so it shouldn't be that hard to figure out. The space is 30 inches wide so the big curves have to be the 13 3/4" 45 degree radius 20-132 and I see 8 of those.
That makes the inside curves 12 3/8" 45 degree 20-120 Likewise 8 plus the reverse for quantity 9
Then the smaller ones 13 3/4 " 30 degree 20-130 quantity 4
12 3/8" fifteen degree 20-121 quantity 5
20-140 15" radius quantity 2
then the turnouts and related
20-150 28 1/4 radius quantity 2
20-202 left #6 turnout quantity 1
20-203 right #6 turnout quantity 1
20-220 left #4 turnout quantity 4
20-221 right #4 turnout quantity 4
20-300 Left hand 15 degree crossing - 1
20-210 double crossover - 1
Then the straights - they have done some strange things with the straights so a bit harder to figure out looks like this is close
20-000 248mm - 21
20-010 186mm - 14
20-020 124mm - 9
20-030 64 mm - 6
20-092 short track assortment A - 1 need 2 pieces from it
20-092 short track assortment B - 1 need 2 pieces from it
20-064 bumper - 9
And then that one curve in the switch back can be anything you want it to be. Once again without actually measuring, looks like it might be a 20-110 11" radius.
