GMTrainNut
I'm working on an NYS&W SD40-2 project, and need to put a notch in the nose as seen here:
http://www.rrpicturearchives.net/showPicture.aspx?id=1385615
I'm thinking about two different ways of doing this. First thought: Glue styrene layers behind the nose, then file the notch into the nose. Second thought: Cut out the area to be notched, and cut styrene bits to fit.
Any thoughts on which way would be best to proceed?
Many thanks in advance.
