I am new to model trains after a 20 years break when I was a kid. Last year I built a HO scale layout on a 4x8 piece of wood. It worked for for my 5 year old. I was running a Bachman DCC controller with with an extra transmitter so my son and I could "play" together. I had a basic layout with ez-track.
Well....
I recently tore down the setup and started from scratch with a N scale layout. I used the same 4x8 bench, and invested in a lot of Kato track. I made the lay out and working on the scenery. I am running into an issue that I need help with. I do in-fact have a lot more railway then the last setup. I am still using the Bachman ez-controller that is only 1 amp. I like this because my son knows the controls in and out. I am running 3 Kato AC4400es with digitrax decoders, and one Bachman train with dcc pre installed. I have 4 power lines running to different locations on the track. The trains first started running great, but started lagging and stalling in certain areas. I noticed the track was VERY dirty and even kinda grimy. I cleaned the track very well, and scrubbed off the dirty areas. I found this strange since I have less than 30 min running time on the track. Well the stalling continued so I played with the rail joiners. I did not know this would be an issue with Kato track, but they were loose. I soldered the loose joints and it was a little better for a little while. Then the trains retired back to being sluggish in the same areas. Another strange thing happened. Every once in awhile I noticed the train was working great, but I would loose control of it. It was like it was running on its own, but would suddenly come back to life. Any ideas? Would a booster or new controller with more amps clear things up? Can a train run better on a dirty track with more power?
Thanks for any advise.
G
Well....
G
