Got the BLI dc analog unit to hook up. sounds easy enough to do. So I follow the instuctions, hook up the one pair of wires to the variable dc part of my more powerful powerpack, and the other i wired with my control track on my longest mainline. Ive been using my Blueline loco to test and im having a couple issues:
1. It negates the use of my Selectors. By that i mean the atlas selectors that you use to control wich segments of track are under control under which power pack. (i have two pwr packs and 3 selectors w 10 sections of controlled track). You can actually center the selectors (off like position) and if the throttle is open and the power is on to either power pack, the BLI engine will make noise and move.
2. The BLI analog controller does not function in a timely fashion. You press the horn button, nothing happens. You press it 5-8 times and finally itll sound. then you cant cut the damn thing off. the bell seems to work a little better, but still has limited control.
Anyone have any input, ideas, suggestions. Barring any breakthru here (thank you in advance), ill be calling Broadway on monday to see what's going on. I did a search here and saw one thread where a guy got a bad unit.
