I've used a lot of stuff that is either difficult to work with or doesn't give very pleasing results. Is there something available in the marketplace that is semi-permanent (aka not difficult to remove - like Sculptamold); something that looks like real dirt but that adheres readily to the surface so that dust can be vacuumed up? (Please - no suggestions about ground foam...)
2 problems with that suggestion have been causing me to avoid the use of real dirt:
1. Difficult to collect, prepare and apply
2. My local dirt probably isn't the right color or texture
I got some sand from the coast a few week's back, washed it and tonight i used it, i mixed a batch of paint up to match the sand, applied it then while it was wet i sprinkled it on nice and even, seams to have stuck well
in this picture you can see that i added fine brown ballast, i also have some fine black sand i also used as ballast, and to finnish off some WS fine grass (more grass to come Harold)
Thats great Steve...!!
I'll do the same! but I have to add some fine kley to it because sand in scale N looks like rough ballast...And be shure the sand is glued well because your loco's will not apriceate that..
I got an idea from Joe Fugate and I think I'll stick with it. Use dry plaster of paris mixed with dry tempera paints. The ratio of tempera paint controls the color of the mix. Sift the plaster/paint mixture onto the layout over the painted surface using a small strainer and then lightly mist the mixture to hold it in place. With brown, yellow, red and black tempera you can make almost any color of dirt. The nice thing about this is that it is very fine. I always had trouble with real dirt. No matter how much I ground it up and sifted it, it always seemed to come out too rough with large "grains".
Hi. I can't help with the wrong texture, but any fine gardening soil, dried, sifted, and then mixed with plaster of paris and an appropriate colour of tempura powder or masonary dye would probably turn out to your liking. Spread on the dirt, sprinkle on the P o P and dye combo, or mix it first and then apply to the surface...your choice, and then spritz it liberally with an alcohol and water mixture. Let dry, touch up as desired, add ground foam or tuft grass here and there, etc.
