N scale "bridge" material
WilliamQ
My layout has a long curve, inside a tunnel, running 2" higher than a double track curve. The outside of everything (i.e. the back of the mountain) is open, so I have access in case of derailments, but vertical clearance is limited. Wondering what people are using these days for support material that nobody is going to see. I need something thin and stiff. I'm considering 1/8" lexan from the hardware store, but would like to go even thinner. I will glue a vertical piece on the side to make it stiffer, and it will have several support piers between the two track layers.
Why not use the Lexan as stated above - except put a piece of metal across the above supports for the tracks underneath? 1/16" stuff should work fine and you won't need THAT big of a piece.
Later
