eTraxx
I've been using XTrkCad to design my switching/industrial/diorama layout. That's not entirely tounge-in-cheek as I wanted a 'bit of each' of those. Considering the limitations in size (approx 10'x5' 'around a corner/on the wall) .. figure I had better have a sense of humor.
In any case, this is what I have currently. I started with the plan for the "Third Street Industrial District". This was from "48 Top-Notch Track Plans" by Boby Hayden. I actually found on-line as a 'selection' on the Google Books site .. here .. (it's a 'limited preview' but contains this layout complete.
I said I "started with.." ... and here is where I am at the moment.
* On the left the main line runs through a cut and from under the bridge/trestle leading to the 'dump-bridge' for the Sand and Gravel company. The Anchorage Sand and Gravel Co. uses such .. which the Alaska Railroad delivers. It's pretty much just an concrete version of the old coal trestle such as the one at the James River Branch.
I think if the main line there 'tucked' behind trees there it would hide the fact that it runs into a wall. I could simply curve the track down a bit ...
* Below that and just to the right of the dump-bridge is the Sand and Gravel office and where the aggregates are stored ...
http://www.anchsand.com/portals/3/loadingtruck.jpg
The spur running up to the dump-bridge gives an excuse for bridges, trestles, rock faces, retaining walls .. all the 'good stuff'.
The long siding at the top of the layout are for the expected industrial flats on the wall.
I placed a water tank and freight house (actually just tossed 'em) into my engine service area.
The main line runs from out of the cut and crosses a road. There there is a turnout for the two sidings running down along the road (I put in the Medusa Cement plant .. because it was available within XTrkCad) . .and another switch there splits a siding from the main (lower track) and another that flows into the upper tracks. On the right side the main line runs into the wall (ok. Actually into "someplace else" .. figure I can put something there as a view block .. structures or trees or somesuch.
The small "loop" of green to the right of the road .. figure a small stream could go there .. reasoning is .. the "why" the tracks loop like that! In reality .. would give more oppurtunity for the .. water, mud, sticks and stones, pipes spewing water and so on ...
I used 18" curves minimum on everything but the main - there it is 22" minimum. The era? I am thinking the mid to late 20's. Steam, shorter freight cars and some early diesel. So - have at it.
