MuskegonRR
Hello all..... I look forward to picking everyones brain as I venture into a new realm of Model railroading with building my own layout. I have several years experiencing operating on layouts and am ready to start my own.
I have quite a bit of space to eventually expand into but want to start with the first section. The goal is a large HO scale layout that represents a Main Line service, with several fairly decent local services as well.
I will get to the overview a bit later..... First I am having a hard time getting my thoughts on paper into the computer with Xtrak or other softwares.
I have included 2 pictures of the first section I want to work on. (could not get them to attach so posted them)
The goal of the first section is to have a Passenger terminal that must be reversed into. I also would like 3-4 industry stops that are off the main on a local. The local also will eventually be the lead in to a steel or iron works.
After drawing it out, and reading the forums I realized that exceeded the 30" rule so have redone the bench-work template. I can use an area that is 8' long and 4' wide on the "east" side but need to constrict to 2' on the west side do to a furnace I will go around.
Not sure if this is enough to go on but any thoughts, or advice would be great.
The section will be against a wall and have room for another 4' section Eastbound for the Ironworks and steel mill. The end of that section will "bore" though a wall with a mainline portal, and a hidden portal inside one of the steel works buildings.
