quakers1
The Blue Man
Hello all..It has been awhile since I have said anything here, but after some months of waiting to see if a larger space would open up for a model railroad, I'm glad to say my wait was worth it.
First off, as of now, i do have an unfinished room at my disposal (yes, i'll have to do some work to get it ready...it's not suitable to house a railroad just yet). The dimensions of this space is 20x30 feet. There is a large doorway in the lower right corner (i have plans to possibly narrow it), and there is a smaller one on the short wall adjacent to this corner, which leads to an office. As of now, i have plans to set up a computer in here, which will be used to dispatch the railroad (and possibly other things).
-On top of this, there is a possibility to open the wall on the lower left corner, and create a side extension room as large as 12x20 feet. This would make the layout's dimensions 40x30 feet. If i choose HO scale to model, i'll probably build the side extension. If I go N scale, I might just not go with it since it would create just too much space to try and fill in said scale. I'm guessing 20x30 is a great space to have for both HO and N scale?
Now, we'll move on to the second thing I want to ask: TRACK. On all of my past railroads, i have used Atlas Code 100 and Code 80 track (HO and N respectively). But, this time, i'm definitely going to go Code 83 (if I go HO) or Code 55 (of i go N). Is Atlas track good to use on a large layout???
That is about all of the major things I can think of. Now, it is on to some other smaller questions I have. I managed to write them all down, and I'll list them here:
-My preferred scale to model is N scale, simply because it is easy to model long trains. Some of these trains will have long cars such as Auto Carriers, 89' TOFC Cars, and since it is modern era, big 6-axle locomotives. I have heard longer trains require larger curves. Since I plan on wanting to run 4-5 foot trains (some of which will have long cars), would 20" or so curves do the job, or should I go a bit larger?
-I do hear that slow-motion switch machines are much more realistic, and less noisy. But, i am concerned about their bulkiness. Will they be a problem to use in large yards? Also, which brand of them is better??? Tortoise (by Circuitron), or Switchmaster?
-As with any large railroad, staging yard(s) are a must. In my original drawings, I had the staging in other rooms. But, these rooms will be used for other purposes. Would running ramps behind the backdrop, and having the staging at a location under the layout be a good idea? If so, how far below the layout should it be, and what is a good grade percentage to have the ramps at?
-Speaking of layout height, I am restricted to a max of 48" (4 feet) off the floor of the room due to windows. I stand at 6' 2", but several people i plan having on the operations crew are pretty short, so it would be chest high or so to them. Is 48" a good height for a layout?
So, that is about all I can think of to ask at this time. As I come up with more loose ends I need to tie, I'll post the questions in this thread. Thank you in advance for any advice and help, and thanks even more for reading this message!!!
Cheers,
-Ace
Cheers,
-Ace
