TrinityJayOne
N gauge fan
After some recent posts in Cmaceeepc's layout thread I thought it would be interesting to see what people are using for their layout control (as in turnouts, detection, etc, not for controlling trains). To quote myself-
Back in the day on my childhood HO layout my dad built a control panel with a very rudimentary switching system - no switches, no LEDs, and probably no safety. The turnouts were hooked up to twin coil solenoids and their terminals connected to some brass bolts screwed into the control panel, two bolts per turnout. All the common wires ran direct to the power supply, and connected to the other end of the power supply was one those probes from a multimeter. When you wanted to switch a turnout you would touch the probe to the brass bolt corresponding with the desired turnout and position, completing an electrical circuit and making it happen. Not very pretty but it did the job.
For my N layout I'll be starting off with a physical control panel, DPDTs for tortoises and probably some push button switches for scenery lighting (houses, street lights, etc). I've been eyeing off these babies in the bi-colour variant for controlling the turnouts. A bit pricey at $11 each but they sure are pretty, and I like the thicker lever that those cheap generic Chinese switches on ebay don't seem to have.
What do you guys use/plan to use? Post pics if you can!
I'm sure size comes into the equation as well. A physical control panel would be fine for my layout as it only has 17 turnouts, most of which are in yards. As layout size increases and you have more mainline I can imagine that being able to set automated routes becomes more & more desirable.I definitely want JMRI on my layout, but I'm still undecided on exactly how much of a role it will play. Anyone who's used it will agree it's invaluable for programming locos, but I may end up leaving its usage at that. Automation such as signals and block detection is grand and certainly cool to watch in action, but there is also something to be said for the physical throwing of switches. You can still electrify & motorize your layout without removing the need for human interaction. That's probably where I'll start off, and then if I feel the need to automate it later all I need to do is add the brains.
