laying track nail or glue
linder1
Hi all im building a steel mill pics are on the showing off forum but i have a quick ? can i lay my track
and glue it to the plywood instead of nailing it. im not using any cork board. thanks
Yes glue it using cheap latex caulk. Its easy to remove if you want to pull the tracks up. Just don't put too much down. Put a thin layer down, press the tracks into it, and weight it down with a soup can.
When you glue or chaulk it down, you can make final adjustments to it before the glue sets up. When nailing it, you can only adjust after pulling the nails back up.
