Hmm-m-m ... I'm not sure why you would stop recommending the Power Cab. You can always add a booster to increase its current capability, as I have done on my layout. And you can also connect additional throttles for increased operating flexibility.
If you later decide you want NCE's larger Power Pro system, your Power Cab becomes a Pro Cab throttle on the larger system.
In short, the Power Cab is a fully capable starter system that can be expanded or can become part of a larger NCE system. In any case, the Power Cab does not become obsolete.
Longer explanation:
The Power Cab is a DCC command station and a Pro Cab throttle built into a single handheld unit. Like most any DCC command station, it can be used to drive a booster if you need more current.
If you connect the Power Cab to the larger NCE Power Pro system, the command station inside the Power Cab shuts down, and only the Pro Cab portion of the Power Cab remains active. Thus, the Power Cab functions as both a command station and throttle when used standalone, and it functions as a throttle only when connected to a Power Pro.
If you watch a standalone Power Cab's display when it starts up, you'll see it first boots up as a Pro Cab (throttle) only. After a few seconds, when it determines it is not connected to a command station, the Power Cab boots up its own built-in command station.
In my opinion, NCE erred in choosing names for its products that invite confusion. Power Cab, Power Pro, Pro Cab ... yikes!
- Jeff
