If these are the "just plug lighting system" type lamps it is 24VDC.Can anyone confirm what the input voltage are the Woodland Scenic's lamp post lights operating at?
So you trying to figure out how to use the lamps without a hub?I saw the voltage out for the power supply for the LED's from Woodland, but the power supply connects to a Lighting Hub and the individual LED fixture are then plugged into the Lighting Hub. The Hub has individual rheostats to control the intensity of the LED's. I'm not sure if they is or are dropping resistors within the Hub.
Do you currently have an accessory bus or are you making a new one just for this?I plan on lighting two industrial areas, buildings and poles and want to use my own buss wiring and avoid the Woodlands extras. Hopefully get the right voltage to balance out the LED outputs.
