Hello say I have a BIG PROBLEM. On my Turntable I made in the 2nd Photo underneath the Layout where you see the two Wires.The Blue/Yellow ones,Ok when ever I rotate or turn my Turntable.Those Wires want too twist and they get tieded up and then they want too.Break off of the piece of Track they are soldered too,Ya seeall I did was Wire one Wire on both Rails of that piece of Track.So there would be two Wires is there any other way I can do this like somehow.Just solder a small piece of then metal too the Track then somehow make a Connection too the Track and piece of metal.Hope ya can help me out here.I just feel so upset now.
Normally, the power to the track on a turntable bridge is routed from the pit rail and either a wire attached to an arch above the bridge or attached to the center drive. Alternately, the pit rail can be split into sections and power can be picked up from opposite ends of the bridge.
It would help to know what type of turntable you have and who the manufacturer is.
Are you using the "tip and rings" of the 1/4" plug for power transfer to the rails of the turntable bridge? That would allow the table to rotate but still provide pickup of power for the rails.
Just a thought.
The pin goes into the jack which has been mounted in the base. The pin, though three pole, only has two contacts hooked up to the track and shack. I put an LED to brighten the shack up.
