Mister Bill
This is my first rodeo with LED’s.
I am trying to luminate an LED from my DC track with wheel wipers. I guess the voltage could be 6 to 12.
I bought a package of Miniatronics Yeloglo White 3 mm LED’s, and after burning out the first one (used the 270resistor), the second one worked fine and is in use (used the 470 resistor).
I tried to build two more using the same procedure and promptly burned out the LED each time.
I was holding the resistor in my bare hand and it might have taken 20 seconds to fiddle with the solder so I got asolid connection. Could I have burned out the resistor with 15-20 seconds ofheat?
My soldering iron is 18 watts.
On the good one, I cut the long leg ofthe LED. On the ones that burned out, I did not cut the long leg.
Does it matter which end of the resistor is soldered to the long leg?
Does it matter which LED leg the resistor is soldered to?
I appreciate all of your advice, but this came as a kit, so I though that the resistor selection should have been thought out by the manufacturer.
Bill
Bill
