diezmon
Ok, so I've got the bright idea of making a modular layout. Since I don't have the room for a permanent layout, and I want something that's easy to move and store.
What I'm going to do is cut a 4x8 sheet in such a way that it makes two "L"s, with the long parts connected..
I've been dinkin' around in XtrkCad with different ideas. based on some of my "wants":
-mountain railroading
-long main line running
-good track to scenery ratio
-minimal grades
-non-sharp curves..
I've left everything out but the mainline run in the images, because I want to get ideas on that first.. then I'll move on to sidings, industry, towns.. etc..
here's the overall view (click images for larger views.
The lower-most level:
And the upper:
I'm hoping that I can use the layout for display at some shows, or for the local neighbor kids etc.. so I'm not terribly adamant about having mucho switching, train schedules, or realistic operations. I guess you could call this a "railfanning" layout.
The curves are 12" min, but mostly 14" and 16", and I've kept the grades in the two helixes at 2%
I actually am thinking of a few well placed switches that would allow and upper train running while a lower train runs.
I've been googling plans and reading every "layout discussion" forum I can find for ideas and I'm not expert on design.. Plus, I'm sick of staring that this shape!
I've already had a suggestion that the helixes are a problem area.. I'd been wondering about those helixes myself.
The thing I want to avoid is a single lap around the layout. I'm trying to squeeze two laps in, and have an interesting multi layer effect as well.
One thing I left out in the upper plan was the scenic dividers.. I was picturing a single board along the length, then actually having the two big "squares" broken into two, or three, viewing areas each. I like the idea of having scenes, so the entire layout doesn't look exactly the same.
Here's another revision I'd done, with the dividers in so you get an idea. In this one, the right helix goes up counter-clockwise, then grades back down just after crossing over the lower level in the upper left area. This plan doesn't allow the running or two trains though..
Then there's the very first draft.. pretty basic. I can't really explain why I don't like this one.. I just don't
So here I am.. what do you guys think?
Thanks!
Tim
-minimal grades
-non-sharp curves..
And the upper:
Thanks!
Tim
