Hello. UK modeler wants 1950s help
Deveron53
Hi all, I will admit to having a fixation for 'Big Boy' since about 1972. My late father and I always wanted to get the Rivarossi in HO but funds were never available and as time went on, it slipped further from our grasp.
Now, as I approach my 54th year and have a house and a garden, I feel ready to start planning...
I'm thinking of a mid-1950s mountain desert layout in my garden.
Welcome to the group Deveron. Any questions you might have, throw them out there.
Welcome aboard Deveron! I don't model the 50's, but there's a bunch of guys on the forum that do. I'm sure they can give you some help.
Hi Deveron. Are you planning an outdoor (garden) layout? I know you mentioned HO in your post, is that the scale you are thinking of going with?
Thanks.
My main question is: what's the best HO Big Boy manufacturer? I want something with nice slow speed control. From what I've seen, the Rivarossi seems to be smooth on start up.
Next, what wagons (cars?)? I'm assuming box cars and tankers etc. How do I tell what's proper period equipment? I need a long train as I'm building a garden layout. How many cars to look good without overpowering the locomotive?
Yes, I haven't got a massive garden but I can run HO with more realistic curves.
I have just worked out my garden dimensions.
Imagine a large capital 'L'. The longest stick is 65ft x 13ft. The other stick is 56ft x 20ft. So I've got quite a good run. I intend to have the main scenic line along the two longest outer sides with an approx 15ft radius 90 degree bend in the middle. At each end of the 'L' I will have 5ft radius curves.
I'm not going to do a lot of shunting and fiddle yard stuff. It will just run at scale speeds around a huge loop while I sit back and drink beer. Occasionally I'll run a diesel powered passenger train.
Scenery will be natural rock and small plants. I will have a large shed at the end of the narrower stick. This will be the storage shed.
The answer to that question is easy, but requires a long explanation. The answer is Trix / Marklin. Trix and Marklin are the same model except that Trix is the made for USA model with 2 rail power while Marklin is their standard 3 rail design. The hard part is finding them since they have not been produced since the early 2000s. Normally I would not have even mentioned the Marklin model, but two reasons. First, I see that you are from the UK and Marklin is probably much more common over there than it is here in the USA. Second you said "outside". Outside and HO don't normally go well together, but the Marklin 3 rail studded track might work better outside.
All Rivarossi are not created equal. The Big Boy made by Pocher starting in the mid 1960s through the 1980s was sold in various versions and under several brand names including Pocher (in Europe), Rivarossi, AHM, and IHC. The line was sold to Hornby models in 1981. These early models are not nearly the quality of the Rivarossi version that was released by Hornby under the "Rivarossi" name in the 1990s. I believe that Hornby is still producting a "Rivarossi" Big Boy but I don't know if it is the same or a yet newer version. So the bottom line is that the newer the Rivarossi model the better. I do not recommend the original design as they had some issues with gear boxes and valve gear binding. The first part was easily fixed with a set of gears by Northwest Shortline but once again more expense and work effort spent on a so so detailed locomotive.
Other non-brass manufacturers that would be a better model in both detail and running quality are:
Broadway Limited Imports, BLI for short, (I think 3 different versions) Paragon, BlueLine, and Paragon 3.
Athearn Genesis
And I hate to say ... Mikes Train House, MTH for short. I personally refuse to do business with MTH because of their corporate behavior and ethics issues.
While I don't specifically own any Big Boys by these companies I have many other steam locomotive models (including Challengers) by Broadway Limited and Athearn Genesis. I can recommend them as a brand in general.
All USA freight cars have a build date painted on the side. They also have rebuild dates. So as long as that date is less than 1959 it would be prototypical. Most prototypical common dates would be less than 1951. Basically any standard 40' box, flat, open hopper, tank would work as well as ice hatch reefers would make a good prototypical train for it. Avoid covered hoppers, center beam lumber cars, and other specialty cars.
Length of train will depend on the specific model of the locomotive you get, any curves and grades on the track. Prototypcially a Big Boy would pull a very long train.
For your information - the minimum curve a real big boy can turn is 20 degrees, which comes out to about 40" radius in HO scale. https://www.steamlocomotive.com/locobase.php?country=USA&wheel=4-8-8-4&railroad=up#346
Models can turn much sharper than that.
As stated above, outside and HO don't usually mix well, but it has been done. It is hard to keep the track clean enough for good performance inside, let alone outside. For that reason, you might want to consider a battery powered control system for the train.
Hope this helps.
As Iron Horseman stated above, there are many manufacturers. I had the 2000's version of the Rivarossi first. I ran OK, but was not good at slow speeds. It met an UN-timely death in a fall off of a shelf OOPS. Two years ago I got the Broadway Paragon 3 version with sound and smoke for my birthday. It is an amazing engine period. Crawls as slow as you'd ever want it to.
Here is a picture of it.
http://www.modelrailroadforums.com/...ds/jeromes-switcher-roster-v-2-0.26282/page-5
