I play with the volume, as I think the default is too loud. I keep the master volume the same, but make everything else (except the horn) lower. I do it in Decoder Pro, as it is easier. If the loco doesn't have dynamics, then I make them silent (F4?).
I also set the brake squeal, I usually change the lighting so that it is dimmable, and have the lights run independent of the locomotive direction. I play with the speed a lot, including momentum, braking, and a speed curve. I turn off BEMF since I have problems with it at times.
