T
tmiller
Guest
Hey guys,
I hope someone has some insight as to my problem. I recently replaced all my Bachmann EZ Track with Atlas code 100, and Peco switches. 18" sectional track was used for the mainline curves, and flex track for the rest. I have a 4-6-2 K4 and a SD70 diesel that work fine around the layout in all directions.
My problem loco is a Bachmann 2-10-2 steam. The front truck is not spring loaded, as some are. Wheels are in guage. The loco seems to run around the layout without any problems, with the exception of one curve. Although the curve in question is slightly smaller than 18", the loco navigates through it without fail going into the right-hand curve. The direction in question, is a left hand curve coming out of a left hand turnout. About 4 inches from the turnout, the front truck lifts up from the inside rail, and does so for another 6-8", before settling down.
From what I have read, there are several isuues to look at: level the track, check the gauge of the front wheels, and the rails. I have shimmed the track to level. Now, being new to laying track, I did find that my track nails were pulling the rails in. I releived the nails and the rails did straighten out somewhat. But still a probem. Using my NMRA guage, I checked the rail spacing. It might be slightly out of gauge, meaning the rails are too close together. The gauge slides between the rails, but is a little tight, hearing scraping, so I assume they are slightly out of guage. Not knowing how to correct this issue, especially on a curve, I have tried to lightly file the inside rail, hoping to increase the spacing of the rails. As of right now the filing hasn't seemed to have fixed anything. The guage still scrapes slightly. I don't know what else to do to correct this situation, other than possibly replace this 18" piece of track.
I am at a real loss as to what else I can do. I hope someone has some ideas. Greatly appreciated. Thanks.
Ted
Ted
