Hello everyone, we're having an electrical issue on our new club modular layout. Hopefully some of you have had similar issues and can share how to solve the problem.
We're using a Digitrax DCS 200 command station and two DB 150 boosters for power. The DCS is wired to main track one, the first DB 150 is wired to main track two, and the second DB 150 is wired to all yard and industry tracks.
The idea being that we have 3 power districts, so that way with plenty of power to operate all 3, and there's insulated joiners separating each track from the other power district at every crossover switch between the mains and every yard and industry track
The wires are connected across the booster input lugs to be sure the boosters are slave boosters, and not command stations, and are not set up as reversing boosters and Loconet cables are connected to all three units.
The problem we're having is any time any locomotive, steam or diesel crosses the insulated joints between the power districts of main 1 to main 2 or main 2 into yard tracks, there's a brief dead short that stops the locomotive.
Some locomotives can make it through, but the short is still obvious on the system and the movement of the locomotive hindered by the short. Any suggestions on how to solve this problem, how to put the boosters in phase, or so on would be greatly appreciated. Thank you.
