stang_crazy
Well the original room i was going to put my layout in, is gonna be tore apart and closed off for a while.
So i decided to move to a different room. Ive attached a pic of what the room looks like. Sides A, B & D are all concrete wall. The grey area is still open but i dont want to go into that as thats gonna be shelf area and i have some pipes ect back in there ill wanna get to. So ill either build a lift out section to get back in there or ill just go under the table makes no difference to me.
Also the door way i could build a lift out to but if i can get away from that id rather keep it open.
I would like to have a loop from B to C or from C to D at least. Then A and what ever side might be left would be for a yard ect. So any ideas on how to go about this. Id like to have a 22" radius for the loops if possable also would like an inside & outside track that way if i wanna let a few trains loop i can. so if im correct the inside loops would need to be 18-20" radius if there running side by side.
So any ideas on this. Or even if ya have other ideas on how i could laythis out other then what i mentioned thats fine by me. Since i dont have my original room i can do the track plan i wanted to do.
My question is how to layout the bench work. I like to have something on all 4 sides A,B,C & D.
thanks in advance Mike
