Control Panels
I'm using the tried and true Atlas (for the most part) on mine and several turnout switches I got from Willie.
All 13 of the turnout switches are wired and working at this time.
Mine was made of 1/2 leftover plywood from the grandson's train layout and about 1 full can of green paint (because I needed to get rid of the paint anyway). It is attached like a shelf to the train table.
And no I haven't connected the 2nd controller yet! :rolleyes:
I like what you have done. This is basically what I have done in years past on many layouts. With this picture, I would like to see the underside picture of this hookup. A more instructive photo of the wire hook ups on the underside.
How to find more pictures like this.
Here is one of my older control panels. I do the artwork in Powerpoint of all programs, print it on a laser printer (ink is waterproof) and laminate it between two sheets of 0.093" thick lexan (polycarbonate). I also add a layer of black cardstock behind the paper to act as a light barrier. I like lexan more than acrylic because it drills easier and tends not to crack like acyrlic. I don't glue any of it. I put the corner holes in first and use a set of screw to hold panels together while I drill the LED and push button holes. I apply pressure to the whole surface with my hand while drilling the holes to preven the paper from tearing. I have a special set of bits I only use for drilling lexan so they stay super sharp. Lastly I start with a small 1/16" bit and drill all the holes and then enlarge them to the final size from there.
I can build the whole panel at my work bench then install it where it needs to go.
Last thing I do (not shown) is after it is mounted I add a protective border around the panel to protect the pushbuttons. I learned the hard way that this is necessary after I had a broom fall over and shear off all the buttons on one of the panels. grrr. had to replace all the buttons on the panel.
https://www.coloradofrontrangerr.com/construction/block-detection-and-signaling/control-panels
