Alan Curtis
I have acquired an Atlas Master Alco RS3 with Loksound decoder. Andersley western runs long hood forward and this one runs short hood forward. Anyone know which CV needs changing to reverse the direction?
Find the manual, or go to the QSI site and download the PDF for the decoder model you have. Look for the CV dealing with Master Volume, and reduce the highest possible value by about 40%. That will be a good starting point.
You will need first to access CV49, if I recall, and enter a value of 0. Then enter CV 50, or whatever the manual says, and set the value in it to 60% of the maximum figure allowed. You'll find the auditory experience a lot more pleasant at that level with the added bonus that as you work near another locomotive, the ones furthest from you will fade largely from hearing instead of competing from 10 feet away.
On mine/ I set CV63 to 25. Volume is a matter of personal preference, but that volume level allows me to clearly hear the engine anywhere in the train room. Setting CV3 and 4 to a value of around 125 will help slow down the starts and stops.I just changed to the next odd number. It now goes the 'proper' way
Now, which CV to change to reduce the sound volume. It is a bit too loud for continual use!
If his RS3 is like my C425, there was nothing in the box, except an exploded parts diagram.But it doesn't have a QSI decoder in it.
The master volume for your Loksound decoder is CV63. This basic information should have been included in the paperwork with your engine.
Mark.
Had a search for UK suppliers of Loksound decoders, and ones that do have them are way more expensive than in the USA. Checked postage on some in US on eBay and postage is not bad. But are there any US suppliers anyone can recommend for me to get specific decoders for specific locomotives? Most decoders on eBay do not say what sounds are loaded (if any). Are they just blanks which need programming with needed sound?
Unless you're using a non-standard decoder or DCC system, most of the CV's are now standardized. There are ranges of CV's where different manufactures can put special codes. Look in your decoder book or use a "calculator" as needed.
