vanda32547
Happy New Year All,
I was playing around with a couple of ideas this weekend and here are the results.
First lets use wooden coffee stirrers cut to fence scale height and make a couple of fences out of them.
I used elmers white glue and used a long stirrer behind all the smaller planks. Then I used round toothpicks as uprights to hold up the fence. I drill a small hole in my benchwork and insert the toothpicks. Since they are tappered they all go in to the same depth. Then I glue the fence to the toothpicks and clamp with clothes pins until dry. I can then remove the entire assembly and add additional glue for a sturdier bond.
Second I used screen porch plastic screen to make a different kind of fence. As you can tell by the pictures I again used toothpicks for my posts and staggered them. Not a bad result for using items I had around the house.
Keep in mind I still have to stain and weather the posts, wooden fence and I will probably spray the black fencing silver and add some rust and corrosion.
Let me know what you all think,
