gregc
Apprentice Modeler
i just received a brass 0-6-0 engine by Gem i acquired on ebay for what i thought was a very reasonable price. but after reading about how old these engines are, and craftmanship at the time, i wasn't sure it would even run. furthermore, it has a motor that sits vertically and mates with the drive gear between the axles. the motor is stamped with KMT.
i was relieved to see that the motor works, and could work at low speed. but i quickly saw that something was binding. it looks to me that it's the crosshead, the part connecting the rod going into the cylinder and the coupling rod connecting it to the driver. it looks like the rails it slide on are too tight at the far end of its travel closest to the cylinder.
i bought the engine to run, not as an investment. some cleaning, filing and bending of the crosshead rails helped. and while it was most pronounced on the one side, i realize the same problem in on the other.
is this a typical problem? should a little filing fix the problem?
