Atlas Commander DCC system problem
PEIR
Eastern RailNet
I have an old Atlas commander that I use for programming (2' section) and testing locomotives (10' section) of track. I tried to program a C424 with NCE decoder and when I went to test the unit it took off at full speed. I tried a previously programmed unit that had worked fine and it did the same thing as did a unit with no decoder at all. The display shows "Con" and "ER 9" when it is plugged in and will not turn off unless unplugged.
Is there a way to do a factory reset on the system or do I have one of the settings screwed up? I don't have a layout and don't want to buy a new system unless it is absolutely necessary so any help would be greatly appreciated.
Stephen
Thank you for the help Mark! The con and er 9 were in lower case not upper like I had typed but you knew what I was talking about anyway:o Everything is working the way it is supposed too:cool:
