The Athearn locos were designed to provide a decent but cheap entry to serious model railroading. To accomplish this, it was necessary that the locos could easily be assembled and mass produced. Unfortunately the electrical and the mechanical aspects suffered as did quality control because of the requirement, but people with little dollars to spare got their moneys worth and more. True the flywheels are not balanced, the shafts and gears are just so, and if a person wants a perfect running model, well those are available too but at a much higher cost than the Athearns were. To bring an Athearn loco up to the same specs as (? a favorite top line loco
) would not be feasible for money spent, it would be better to buy a top quality loco in the first place. However a lot of MR enthusiasts don't have the $$ to put out for the best.
Now for those seriously operating on a budget, the Athearn is definitely a decent loco for the price. That said, with a little work and next to no extra cost the running characteristics can be improved immensely, that's all these tuneups do. At the time I started the only models of the MLW C630M were Overland brass. $600 apiece not counting tax; shipping etc. and I needed 10 of them. No doubt a divorce would have been in the works if I had of tried that. However the Athearn U33C and a couple of Tyco shells filled the bill, so for about $120 each I got my fleet. (I've only built six so far and each one gets a bit better)
The gears sometimes do have some little spurs (flash) that should be filed or cut off. To leave them there because the gears can still turn is ok, but a definite improvement will be noticed when they're gone. Running characteristics are improved immensely by replacing all mechanical/friction type electrical contact surfaces with wiring. Stopping the motor from wobbling reduces the binding there for noise reduction. All those things do not bring it to the same level as, say a Proto or PK2 loco but improvements are noticed none the less.
I do agree about the pearl drops (whatever they are) and tooth paste etc., but a lubrication is necessary. What I use is the Precision Oiler from Radio Shack.
It has micro miniature particles of Teflon and Fluon (whatever that is?)
Descript.
-Super slippery lubricant resists dust, does not coagulate, and has no oily residue.
- Unaffected by temp extremes (-51C to +260C)
- Penetrating action frees "frozen" nuts, bolts, locks and bearings.
Anyway doesn't harm plastic so it works for me
Cheers
Willis
