I do use rechargeable batteries but only in devices that will fully discharge them. For other devices you can pull them out and use them in flash lights, but now with LED flash lights the batteries seem to last forever.
I'm using LiIon, and while they don't start out at a full 9V, they also don't run down anywhere NEAR as fast. I was having to recharge NiMh every time I turned around, seemed like, and since I switched to LiIon a couple weeks ago I'm still on my first battery. And that's with forgetting to disconnect the battery on several occasions. The problem with NiMh is that they do just keep decreasing in voltage to the point where the controller quits communicating. With LiIon it'll maintain a working voltage right up until the point where it dies.
Not all rechargeables are created equal. Lithium Ion batteries do not develop a memory, and do not need to be fully discharged before recharging. In addition, they maintain a good working voltage right up until the moment they die rather than slowly tapering off like NiCad or Nickel-Metal Hydride batteries do.
I figure the Lithium Ion 9V's I bought are well worth the investment. They'll last much longer and work better than the NiMh. They'll pay for themselves quite easily over their life. Then there's the bonus of not having to be constantly replenishing a stock of batteries or running out of them and not having any.
For rechargeable batteries Lithium Ion batteries would be a better choice over Nickle Cadmium in the long run because battery "memory" is less of a factor. Unless of course you have 2 or more sets on hand and you don't mind recharging more often.
Devices that don't completely discharge the battery before the battery becomes unusable are not a good application for Nickel Cadmium. They work best when fully discharged before recharging. If not the more you recharge them the more they will need to be recharged.
I usually buy the cheapest alkaline battery I can find, about 25 cents per battery or less for AA or AAA. There are only so many battery manufacturers in the world. Find a place that sells a lot of batteries and you will get good fresh batteries.
Thanks for the replies, guys!!!
Thanks for the reply, Mike. I am glad to hear of someone having success with Li-Ion 9v rechargables as they're actually cheaper than NiMH. When I heard warnings of 8.4v batteries, I suspect it was in reference to the NiMH and NiCd 8.4v batteries instead of the Li-Ion. How long have you been using the Li-Ions and what's the longest they've lasted for you? Our operating sessions are usually only about 3 hours, so if they can last that long, that would be perfect.
Brandon
Thanks for sharing your experience! I may grab one of each and just see what happens. I'm a little nervous about the voltage being that low. Do you know what the cutoff voltage for the Digitrax throttles is?
Also, be careful not to take that battery too low... over-discharging li-ions can damage them, FWIW. I would recommend stopping at 7 volts, although it sounds like it's going to take a while for you to get there!
Brandon
...When I heard warnings of 8.4v batteries, I suspect it was in reference to the NiMH and NiCd 8.4v batteries instead of the Li-Ion...
I agreed with your choice of rechargeable batteries for this application.
While it is true that Lithium Ion batteries are far less effected by battery memory they still suffer from repeated charging when not fully discharged, The effect tends to be more in longevity rather then capacity. You can't believe everything manufacturers tell you because they only tell you the features not the deficiencies.
No need to apologize to me. I believe this to be on topic, personally.It all factors in to some degree. Although some of us prefer to go into deeper understanding than others...
Brandon
Apologies, Louis. I'd read a tech article about a year ago which stated what I did above. They apparently glossed over the effect as being non-existent rather than saying it was comparatively negligible. Thanks for the info.
Like the old snake oil salesmen manufacturers will say almost anything to make a profit. I just don't understand why they have to lie even about great products.
Some people would rather climb a tree to tell a lie, than stand on the ground and tell the truth.
