Another one starting out, more questions
sajordan
Well, looks like good timing. I’ve spent the last month clearing out the RR room, and studying books, websites (this one), and lurking on E-bay. The snow just started this AM and I’m ready to begin a small section of layout. I’ve got a small space between the main door and the “under the stairs” closet. I plan on a table of 30” x 60”, a small yard located on the PacNW coast, with old wooden piers, maybe a tug. I’m still not sure of bench work or sub roadbed. From looking at a few of the previous posts, looks like most are not bothering with Homosote, and sheet foam has taken over for the base. Jonyb is not even using a cork roadbed under the rails? So the questions are as follows…
For a small narrow gauge steam RR, would they build up a roadbed in an industrial area? Should I use cork roadbed and would N scale bed look a bit better for small cars and locos?
Do you spike or glue down the flex track? I’ve seen both mentioned. This layout is in the basement, AC and heating and a pretty dry area of the country.
Dreaming along, I thought I might put in a hidden loop, to allow continuous traffic thru and back to main layout. With only 30” width, is a 14” radius curve reasonable? No motive power yet, but the largest loco planed is a 2-8-0 (Blackstone is the only one out there in Hon3, how’s it for slow speed/DCC control?)
Thanks, SAJ (still with lots of other questions lurking, but so far I’ve learned a great deal from the other posts. I’m spending too much time surfing and not enough building!)
Here is a link to Wolfgang Dudler's blog, where he did some experiments on H0n3 engines for his layout (bottom of page): http://www.westportterminal.de/blog/blog09-05.html
His conclusion seemingly was that for most of the H0n3 steam engines he tested, the absolute minimum radius was 15", but that the engines were a lot happier and looked better with 18" radius.
Smile,
Stein
Thanks for the information. I've decided that the space I have is just too small for a loop. It will have to be a dead-end yard, with maybe a roundtable.
