Air brush painting questions
oplholik
Just bought an air brush compressor at Harbor Frieght, so will begin practicing and learning how to use the air brush. I have a Paasche Single action external mix airbrush. I will be using to begin with, the Folk Art acrylic paints from Wal-Mart that I have. So my first question is, for painting plastic, other than making sure it's clean, is there any other prep to the plastic to do for painting the plastic?
Next question concerns making a box for a small spray booth and what fan to use in the back of it that won't cause a spark and an explosion if I'm using paints and thinners that are flammable. I have a portable air filter that would be perfect for my uses(pic below), but it is clearly labeled not to use near volatile paint fumes, so, so much for that.
Google "brushless fans for paint booths". Brushless fans, if sealed right, are sparkless - according to what I've read.
If you have a Grainger or McMaster Carr store for industrial supplies near you they can be a good help to pick something with the right safety ratings. It shouldn't cost that much to buy the right safety fan. I wouldn't trust something from a regular hardware store.
And -- good move thinking about that safety concern. Some don't and pay the price.
Here's a nice write up.
http://pages.interlog.com/~ask/scale/tips/booth.htm
And now that I think about it, the on/off switch for the fan should be sealed (sparkproof) as well. Running it on a switched outlet far from the booth might be OK. Plus the lighting is a concern for explosion safety if a bulb pops. Maybe LED lights?
I do all my airbrushing outside. Nice SoCal weather makes that possible. The only time I don't paint is when it's raining (rare). You could always put that booth on wheels. :)
Thanks Charles. I will most likely do most of my painting outside also, but where I live, past mid morning it's pretty breezy, so still need something to protect from the wind.
True spark proof blowers tend to be very expensive. However, some squirrel cage blowers put the motor outside the air stream, which can provide a large safety factor. I recently found one on Ebay that is destined for my as yet unbuilt spray booth.
Don't use any axial (in-line) fan, unless it is marketed as spark proof.
