I did, there is no instructions available, I believe its the original tooling and Walthers doesn't have a any information on the product.If its a product that is still in Walthers catalog, go to the Walthers website. For most Walthers kits there is an option to download the instructions.
Tried it but doesn't have the motorized version I need the gear box diagramThey might be on HO seeker.
No it looks like thisIs it the same motor as the Walthers Motorizing kit? There's an instruction sheet that can be downloaded. But no gear box diagram.
Motorizing Kit -- DC Motor & Gearbox for Swing Bridge, Oil Pumps, Turn
Animate your models in minutes with the Walthers Cornerstone Motorizing Kit. This fully assembled drive unit is a drop-in mount for Walthers Double Track Swing Bridge (933-3088), 90' Turntable Kit (933-3171) and the Walking Beam Oil Pumps in HO (933-3170) or N Scale (933-3248), all sold...www.walthers.com
I believe I have figured it out, Ill post a picture of it so if anyone ever has this problem again they can refer back to it.Well I’m afraid I can’t help, all I have in the box is this…
I have two of the cranes, one unpowered and one powered that has been dismantled for parts.
I’ll keep an eye out for better instructions
It looks like one of those gears is cracked. The upper white one, in a line with what looks like the two worm gears.I believe I have figured it out, Ill post a picture of it so if anyone ever has this problem again they can refer back to it.
Walthers motorized American Crane.
Thanks for the help and support also.
Yeah, I'll find some new ones the entire crane is a mess. It has NS MOW frame a BN cab Athearn bluebox gears on the axels and the cranes arm is broken, but it doesn't look like a bad project.It looks like one of those gears is cracked. The upper white one, in a line with what looks like the two worm gears.
