I've decided that instead of modeling the F40PH-2C, I'm going to model an MBTA GP40MC. I'll be starting off with an Athearn GP40x, but I know I need to lengthen it. What size of sheet styrene matches up with the Athearn shell is my question?
I'll try to remember to measure one (GP40X) when I go to the train shed later today.
My guess is generally around 3/32nds, (.093) There are likely many places on a shell that will measure more or less than this.
If you use two Athearn shells you won't need to worry about matching thickness.
I was thinking that! I may buy an sd45 shell since it has the same style flared grills.
The reason I ask is because I need to lengthen the GP40x to fit over a Dash 8 set of chassis since that's the closest to the length of the MBTA GP40mc. But I think I got my answer! Thanks guys, I do appreciate the help!
If you still need to know, the thickness on my GP40X's varies from .055" to .062" depending on where it is measured. That is slightly over 3/64".
