Running Bear's Coffee Shop LVIII
Good Morning All. It's clear and 45 degrees here in North Central Texas today expecting to hit 70+. Looks to be the pattern for the next few days.
Garry, Curt, & David (& others) - Thanks for the comments on the pictures.
montanan - Nice lumber yard scene. I'm working on mine with the same Atlas kit, I'm using Pikestuff parts to build to build the extra building and have a concrete unloading ramp. Pictures once I finish the fence.
That's it for now.
Willie
Good morning guys. Have to figure out the issues with my layouts wiring. Something seems to be wrong however I am able to run em if I choose to. Just not in the manner I would like or rather how I pictured it.
Sent from my XT1031 using Tapatalk
Well figured out its not my wiring. Be nice if my dumb self would have isolated my blocks right on the right common rail....
Good morning all, we have 30 and cloudy. Supposed to be mild all weak, really easy on the heating bill!!
Chet--Nice job on the streams. Really nice.
David--my hand is well and I am getting stuff done on the backdrop frame. I started running wires and hooking up the lighting last night. I will be out of town for a couple days buy by the weekend should have the frameworks completed, up, and ready to attach the vinyl.
Looked like the forum here was the ONLY place I saw ANY mention of Pearl Harbor. How quickly they forget.
There's the difference between our layouts. I have each block totally isolated, not just a single rail because I do have two different throttles to use.
I have dual throttles as well. I have selectors hooked up to my blocks. The issue I ran into was I was getting power through all of my blocks cause I didn't isolate the common rail. Though your way seems to work well. If I had more to play with I would wire it up the same as yours.
Good morning. 44° and sunny this morning.
Chet: The stream scene with the fishermen is fantastic. I really enjoy both your photography and your modeling.
David: Thanks for the suggestions. I have not reached that point yet. Uni-track is preformed sectional track, which works very well, for testing to see if an idea works, but not necessarily the ideal way to build a permanent layout. The other downside, is that track components are limited. I'm still planning on using my cache of Micro Engineering Code 70 flex, once I come up with a suitable plan.
Walthers is re-issuing both of their movable bridges, however, the swing bridge is double track - which would also work, but would deviate from the prototype shared asset feature, which makes for interesting operation.
Like the idea of code 70. Being that you are going to mainly have an industrial or switching layout, and not run long heavy trains (I am Guessing) the looks of code 70 is great. I used code 70 when I started my layout because I really disliked the oversize rail when I was into my N scale layout. Besides hand laid track, I used Shinohara flex track and turnouts. Micro Engineering wasn't around yet. I tried some ME flex track but found it a bit more difficult to keep a constant radius. Shinohara lets on rail slide through the ties easily so transitions on curves are more or less automatically taken care of. I do like the looks of the ME pre weathered track but ended up using it in straight sections of a yard. Being that I started with Shinohara, I have stayed with it.
Good morning ........
Chet .... Your fishing mini scene is fantastic.
Regarding sectional track.... I don't like it at all. ... There is no transition from tangent (straight) track and curve track. Using flex track allows us to make the transition. ... Trains perform better with that.
In our neck of the woods, bridge building and highway construction is in the news. The 80 year old two lane bridges are being replaced with wide four lane bridges over each of the two large man-made lakes. Alos, the narrow two-lane roads is being replaced with a four lane divided highway.
Below is how the Kentucky Lake Bridge looked about three years ago. A river cargo ship went under the wrong span and broke it. Our neighbors were on the bridge at the time of the accident. A replacement span was installed about 6 months later. A new bridge was already planned, and funds were made available to build the new bridge.
Last week, the main span of the new bridge was installed on its piers. The span was fabricated on barges close to the shore, and it floated to the its location where it was lifted up 75 feet. It weighs over 5 million pounds before the pavemnt is installed.
Here it is next to the old bridge. The replacement span on the old bridge is the second one.
We live on the other lake (Lake Barkley)... They started building the bridge here a few months ago, and we can hear the pile drivers daily. The method of construction is not the same as with Kentucky Lake. They are building huge temporary platforms for cranes, other equipment, and materials instead of using barges. ... The long platforms will never be connected in the middle because it would block barge traffic. .... Eventually, the new bridge will look a lot like the other new bridge. ... Our house is out of view to the right in the background.
I noticed that too. I did not hear a peep on the news about it.
Hmmm...Pearl harbor Day was ignored around here too. I just dismissed the local ignorance on the "elitist", self-centered New Yawkers. I suppose that since most of the Pearl harbor generation has now passed, it's no longer important enough to be remembered. For most of my life, it was a major remembrance. Each generation has their own 'event', such as 9-11, although even that is fading in importance.
Chet: Prototype rail height was deceiving. For instance PRR used 155 lb stick rail, on heavy traffic - high speed main lines, and in at least one case, an electrified branch with frequent coal trains. The Leigh Valley, used 136 lb Lackawanna, which was as tall as the heavier PRR Rail. Some 125 lb RE and 140 lb appeared identical. Same with the 100 lb and 118 lb rail used on some main lines in the South. So Code 70 is appropriate for more than just branch lines, and industrial districts.
I first tried code 70 back in the '80s. The Model Railroad Shop in Dunnellen, NJ was a convenient stop back then, and they handled the full Shinohara (Lambert) Code 70 line, as well as Micro Engineering weathered flex. Back then, Shinohara still made a #5 switch, in Code 70. Now they offer a #4, a #6, and larger switches, but no #5. ME rail is a PIA to curve, and there is an instructional video that shows an easier way to do it. I may actually try some Shinohara flex rail when the time comes. I still have several sections of benchwork to fabricate before I can visualize the complete layout.
Garry: Transition is important, however, when using sectional curves, one can simulate transition, by beginning the spiral with a wider curved section ahead of the fixed curve; (eg. 34" rad 10° curve leading to 31.1" rad 10° curve, or 31.1" rad 10° curve leading to 28.75" rad 10° curve). Not quite the same as what you can do with flex track, but when using sectional, it works. Personally, I believe that sectional track is too rigid for a fixed permanent layout, but is sufficient to test fit sections of layout before final track placement. (Since I have it, I may as well use it).
Great photos of the Kentucky Lake Bridge. I'll bet it cost the shipping company and their insurers plenty. Reminds me of when a C4 cargo ship's mast took out the PC's Movable bridge over the Chesapeake and Delaware Canal, back in the '70s. The incident took the life of a member of the ship's crew, and set up some really unique and memorable adventures, for yours truly.
