ConrailRailfan
Hi I have an Atlas Dash 8 40-CW and one of the sunshades fell off and the two things that go into the cab are stuck in the cab still, how could I remove them? Thanks
I would not use a power drill! The chance of damaging the engine is too great.How small would the drill have to be, would I just use a regular drill and a small drill bit?
I tried the pin vise but I can't get it to attach onto the pieces stuck in the cabI would not use a power drill! The chance of damaging the engine is too great.
Put the drill bit into a pin vise to hold and spin the bit. If you don't own a pin vise, you might be able to do it by holding the drill bit between your fingers and spinning it.
- Jeff
Pin Vise:
