Diesel-Electric
Hello there,
I need a little help, this question is for modelers who have around the room shelf layouts:
I'll be making a shelf layout soon (consisting mainly of 9 1/2" planks mounted on the wall with metal L brackets). I'm one who prefers to watch the train go by and therefore it will be continuous running.
However, the room I'm using has an inward opening door in one corner, this would require a lift out section/bridge.
I would like if You can give me ideas and preferably, if possible, some pictures on how You got around this problem? I'm bad at wood work and since realism/appearance is not an issue as this layout is just for running trains, simplicity is of the essence!
I do not mind if it is completely removable section as it would eliminate the use of hinges, which may further simplify it. However securing it in place is a must (duh)!
Ideas would be really appreciated!
Thanks in advance!
Thanks in advance!
