Iron Horseman
I think that will be a serious let down after watching a steamer run.If i can’t get it to work then I also ordered big boys helper, 6-28330 and matching tender.
it’s only a little bit and it’s coming out of the turn so 4 spots in the room.
It’s the nose at the tip of the catwalk. Maybe a 1/4. Maybe I’ll just dig out the drywall lol it’s an old house so the drywall is like a 1/2 thickThe nose or the cab?
Easy enough to patch when the time comes, just sayin'It’s the nose at the tip of the catwalk. Maybe a 1/4. Maybe I’ll just dig out the drywall lol it’s an old house so the drywall is like a 1/2 thick![]()
Yes, provided they are both TMCC locomotives. Program them separately so that you know their engine numbers before running them together.Question for you guys. I can run 2 locomotives simultaneously on the same track with the Tmcc cab1 remote right? Engine “1” then engine “2” on remote?
A siding? The won’t run into each other. They will end up pushing/pulling the other one though. I’m talking about having 2 engines pulling cars. Steam and a diesel right behind.Yes, provided they are both TMCC locomotives. Program them separately so that you know their engine numbers before running them together.
Also, without having a siding it can be tricky trying to keep the locomotives from running into each other when you stop or start them. You must be quick and sure with the cab remote.
I miss understood, you mean two engines pulling the same train. forgive me.I’m talking about having 2 engines pulling cars. Steam and a diesel right behind.
All good. My question is how do I set that on the remote? “Eng 1” then hit eng 2” then go, or?I miss understood, you mean two engines pulling the same train. forgive me.
I would think drywall in an older house would be 5/8" thick. Any older and it would be slat and plaster! Ha. For a 1/4" hit zone, digging out little slots would be the easiest thing to do. Also easy to fill and fix if you change your mind later.It’s the nose at the tip of the catwalk. Maybe a 1/4. Maybe I’ll just dig out the drywall lol it’s an old house so the drywall is like a 1/2 thick![]()
That very well might be a solution. I bought a bunch more track. I’m going to play around with it some more and see if I can get that big steam engine to work. I got a diesel on it no problem. When the track straightens out it’s all the way against the wall I have plenty of room to move it out away from the wall.I would think drywall in an older house would be 5/8" thick. Any older and it would be slat and plaster! Ha. For a 1/4" hit zone, digging out little slots would be the easiest thing to do. Also easy to fill and fix if you change your mind later.
oh, wow, that is close to the wall. Yeah just pull it toward the outside edge of the self and you've got it.That very well might be a solution. I bought a bunch more track. I’m going to play around with it some more and see if I can get that big steam engine to work. I got a diesel on it no problem. When the track straightens out it’s all the way against the wall I have plenty of room to move it out away from the wall.View attachment 201435
Yea unfortunately it’s not that easy because I have that closet making it a royal pain. I think I’m on to something though so it might work.oh, wow, that is close to the wall. Yeah just pull it toward the outside edge of the self and you've got it.
I love the Halloween cars!
Tunnel through the closet instead of going around?Yea unfortunately it’s not that easy because I have that closet making it a royal pain. I think I’m on to something though so it might work.
Thank you sir.I love the Halloween cars!
Your a bad influence!Tunnel through the closet instead of going around?![]()
He is not alone; many of these guys have no problem helping you spend your time and money.Your a bad influence!
