Diesel-Electric
Hello there!
I've started on my very first permanent layout. The bench work is a metal frame, constructed from L shape bars, with a wooden planks on top with roughly equal spacing in between. On to the the top, I glued down sheets of 1 1/2" Styrofoam. The track is temporally pin down directly to the Styrofoam.
(I may keep it that way, as it looks good).
The curves I've used are Atlas 24" radius sectional track (makes the layout look somewhat bigger doesn't it?), hence the 4'4", and the lone switch is an Atlas custom-line LH #4 manual switch. All track is Atlas code 83 NS. I just thought of sharing some shots of a train running on it.
For now, no scenery whatsoever, and will remain that way for some time as I'm having family matters to attained to. But will run the trains on and off!
Comments/criticisms and advice are welcomed!
