Let’s Build a Paper Mill complex for a Friend
I’ve been back at the bench. Some changes to dimensions of 1/4” on the 20.5 x 7.5” shipping department segment changed the post and beam supports and also moved the forklift traffic pattern. Added a bump out office and created 1 of 2 openings to the warehouse
Changed the floor coloring covering (sort of) the former traffic pattern of the fork lifts. Still in process but you get the idea. Tire tracks to be added and the traffic pattern edges feathered out
This is what it previously looked like
The east wall of shipping has changed from the rail dock opening being part of the wall to its not. It will be a lean to type looking shed on the side of the truck docks. Partly why it had to be separated from the east wall is the concrete floor of the truck dock is 1/2” higher than the ground level tracks
Mocked up
Added a bumped out office in styrene
More tomorrow as the west and east walls of this shipping department segment have been primed and glued together and I didn’t take a picture
I bet you thought we were done with bridges! From the West we have the Swing Bridge that had its own thread. Here is a single track bridge line that leads into the Paper Mill from the east
1st couple of pictures show it with a new color, battle ship blue gray is what one of the styrene delivery guys called it this morning. Still it’s better than the heavy dark green it was given to me i
Al light mist of Tamiya Buff
Then getting ready to dry brush some aged white, silver and sand I find some loose bridge parts. The glue is drying
Then time to clean up the bench and organize the paint cart
Wow I missed a lot here, just catching up.
Nice!
Thanks for checking in Rico! You know I appreciate it. This thread will be picking up speed as I am building the Warehouse/Shipping department at 10”deep x 30” long x multiple levels. I have the Final Inspection/Wrap building framed out at 14” long and 10” high. The digester/recovery boiler complex the most complicated build in this thread I have the 5” deep x 26” base cut out, sealed and primed. Between the D/RB complex and the FI/Wrap is another 54” of false front facades at different depth and heights. It’s been mostly a fun journey but it will be a journey, mostly scratched built, quick at times, slow most of the time and times of frustration where I will walk away.
Later today I have another truss bridge to show than sometime this week 2 girder bridges and that’s it for bridges. We need crossings of the Columbia and Wenatchee Rivers in Washington. So I will show them here
I like the color!
Thank you Louis. I did too but the friend wants a roughly 40 year old looking bridge in well maintained condition, meaning little rust. From what he tells me and I have found researching the Great Northern RR kept the track and bridges in fairly good shape. He wants a bridge starting to develope a chalky whiteness to it, basically just before GN would have sent crews in to repaint it. 1965 though I guess was the real start of decline of the GN. I know very little or do I care about PNW railroads.
He has a GN expert as a friend who is in his late 80’s or early 90’s. That former GN lifer has been reviewing the bridges. That was a HUGE color issue with the swing bridge. My friend told me how he wanted it colored and I pretty much did it even though my research, using Ai, GN historical group and my friend’s expert friend said different. My friend finally accepted the Swing bridge as the starting to rust bridge the color ended up.
I mentioned this in the Swing Bridge thread. Doing commission work is much easier than doing work for a friend. I design and submit sketches or drawings to a commission client. Once the design is approved and the design fee is 100% paid I build it. Rarely are there changes. If there are changes though it maybe $$$ costly! Not so with a friend. But now other than payment I am handling my friend as a client. But I want these gifts to him to be what he wants, so we tussle over colors…
This is all truly fascinating. The level of detail in these projects is mind-boggling to me. They are, or will be, museum-quality models.
I have neither the talent nor the skill for this kind of work, but I enjoy watching the process. Only seeing the finished projects, I never truly understood or appreciated the work that goes into creating these models.
Thank you once again for sharing your work.
You are being overly kind and I thank you.
Scratching building is not that complicated or scary In My Opinion
My way, may not be for anyone else but it works for me
1. Research what you want to build (finding images online is a great rabbit hole)
2. Inspect (measure) the area to build in
3. Sketch out the plan
4. draw a base (I use poster board) to see if it fits the given area
5. create a mock up (again I mostly use poster board, it’s $1.25 at the local Dollar Tree+)
6. choose your materials
7. define your measurements (I prefer on graph paper, I’m 73 it’s what I am still most comfortable with)
8. build your base
9. build the frame
10. create your walls and opening
11. dry fit
12. paint doors, windows, walls (inside with black, external with your color of choice)
13. add doors and windows to the openings
14. fit together and glue
15. add details
16. add to the scene
Now I’m not naive enough to say anyone can do it (because they can) and it will look great, because it usually doesn’t the 1st few times. It takes practice. But over all there are good things that happen when you are scratch building or kit bashing. It usually will be a unique build, it fits the space instead of making the space fit the kit. If you don’t count the time spent building it, it will be less expensive. It’s another part of model railroading.
I deviated from my own rules because this paper mill is a gift for a friend and it has cost me in time and materials. I’m now treating it like any commission I would build
Thanks again
I’m done with bridges for the next few months at least!
Started working iron the base for the digester complex
Here is the digester base. It’s actually short for 1965. At 100’ ho scale tall it’s around 30’ short in height of a typical digester in 1965.
maximum height is 14”
I am scratch building the digester building and the blow tank is .080 plain sheet styrene made into a tube and Ca’ed together. The foam tank will be a 2.5” diameter tank created from a wooden closet clothes rod skinned in .020 styrene sheet! The brown stock building is a 4x 8” building that needs the foam tank completed to determine its height. The foam tank will be 2” higher than the blow tank.
Lots of piping, electrical runs, pipe racks and bridges are going to be added.
I hope it won’t be too boring.
The space for the paper mill is:
18” wide from the double track mainline and its length is is sections or what I’m calling segments
1st segment is the harbor entrance with swing bridge 48” completed and installed
2nd segment is the Power Plant To digester. 36” 66% completed and installed, coal pile to be added
3rd segment is the digester to brown stock building. 26” working on
4th segment is BSB to Bleach building is. 20” working on
5th segment is the paper Machine building. 32” drawn up
6th segment is the Final inspection Wrap building. 20” drawn up
7th segment is the Warehouse/Shipping. 30” 90% completed needs removable roofs
Not a segment as I am not doing it shipping traffic. 24” no involved
Wood handling including pulp storage yard 31” to be determined, not drawn
The engine shed somewhere in the pulp storage yard. Structure is complete
Total 267”
I’ve busy!
I took the legs off of a building from a part of an aggregate kit from Walthers the friend had
Added another wall to the digester building
Worked on the legs for the blow tank after I sanded down the tank and prepped it for gluing the legs and the discharge pipe at the bottom of the tank
Finally for something straight forward and relaxing I built a kit. Oil or water tank from Rix Products. It was easy to put together as I read the instructions.
I am on a 3 hour break while things continue to dry Terry did add something to the honey do this list!
The water tank needs to be weathered but is assembled
Needs a base, 4” squares Sintra pvc board is the material, I painted it concrete, weathered it and added a matte clear finish
Add some concrete expansion control lines
Centered the assembled tank, lightly drew in the return lines so the tank does back to the same position, added bollards for protection
Lightly weathered the bollards
Found a fire hydrant (actually can’t find the spares, took this one from my wood chip yard). Weathered it and installed it on the base
Added more weathering to the bollards
I like the base and its details
Till next time
It’s next time. Cut the above post short due to picture limitations, 10 per post. Not complaining, it’s just the reason why…
Checking clearances and it seems ok
Add an overflow pipe
Make sure it lines up with the newly installed hole for drainage
Find a tank topper
Add a pressure relief pipe
The tank is a basic kit. You get the side walls to form the cylinder rinks and you stack them 8 high, it’s the full kit and a formed compnical roof, that’s it. Anything else added needs to come from whatever parts I have
The tank is assembled and painted. I will add more pictures later today or tomorrow. Weathering was to be this morning but the wife says we are taking a day trip. It’s going to be mid 70’s in Wisconsin, need to enjoy it
Thanks for stopping by
Next time
Back at bench and this time on the paper mill. Here is the digester where the wood chips enter and comes out as pulp.
The digester main tower is 12” high or about 6” less than prototype and steps down to 10”. COMPRESSION is the name of this game
The white strips are .060 styrene glued to the digester walls representing an exposed 6’ scale concrete foundation
I placed the green liquor tank next to the digester just as a height check. The tank is 6.75” tall again compressed to fit the scene and space.
Here is the base template. 5” x 26”. While it looks like a lot of space, it’s not. There will be 2 more liquor tanks for white and black liquor. They will be diameter 1/2 tanks glued to the wall. A chimney stack against the wall between the green liquor tank and the blow tank. The recovery boiler will be represented as a facade wall. Much of the the space will have the congestion of a paper mill tank farm where they added tanks where ever they could. Lots of pipe racks, bridges, conveyors and electrical cabinets to fill the space.
Stay tuned
