Modeltrains2021
Hi can put a led in the rivarossi mallet?
Is it DCC or DC ?Hi can put a led in the rivarossi mallet?
I find using a thin piece of styrene glued to the interior bodyshell with the wires sandwiched between, but not glued, helpful, just need to leave enough wiring to remove the bodyshell.The hard part will be routing the wires back to the DCC decoder. I use micro LED bulbs more now instead of the large 3mm LED's
Both should work, LED's are 3v, see how much space you have to work with.Okay will a normal or a micro led work?
That's something I haven't thought of. Hmmm...I prefer 3mm LED's, just dunk in black paint, let dry, and polish/sand the front, wire up and done.
The front of a 3mm LED is quite thick, you can polish/sand the front flat, that will then fit flush with the lens (or take the lens out and fit it flush with the Loco nose), all the light goes forward with no bleed into the loco., but make sure that you dip it past the back of the LED and let it dry thoroughly, if you attempt to power it, the paint will cause a short and blow the LED.That's something I haven't thought of. Hmmm...
