Knowing Status of Turnout Switches
I'm convinced (absent someone here suggesting otherwise) that the way to upgrade the three turnouts on my layout is to purchase the DCC Bachmann turnouts. Okay, so far so good, but a problem arises (at least in my mind). Since I'm using the Bachmann Digital Command Control, how do I know which switch is in what position, other than simply remembering? My three switches are inside tunnels or other locations where I cannot readily see them.
I know the larger layouts have elaborate schematics with lights and such. But, with the DCC Digital, how do you keep on top of things? Surely, there is a simple method that escapes me.
Is there a simple and inexpensive box/unit with lights and such to help?
I'm unfamiliar with the Bachman units, but I'd imagine they would have contacts for indication?
I use tortoise machines with bi-color LED's wired in line. If your switches are stall type motors it should work for you as well.
I also use Digitrax throttles, if I hit the switch button on the upper right and then the switch number on the keypad it shows the orientation.
Does the Bachman controller have such a button?
