Guilford Railman
I’ve applied weathering powders to my ballast and while the brand I’m using is self-adhering, is it best to seal in the powders with an additional method. If so, how do I do this?
I was going to suggest the glue mixture, I think that would work.I was thinking of trying something like that or possibly applying another layer of isopropyl alcohol and glue on top to adhere it. Not sure if it would work but that might be a way to go too.
I have read similar things that dull coat or matte clear coat takes away the effects of the powders and have indeed confirmed it, having just applied powders and clear coat to a structure I’m making.
Good idea with the extra dilution! If I use more alcohol/glue, I’ll be sure to do that.I was going to suggest the glue mixture, I think that would work.
Maybe dilute it down a bit extra. Of course, I would suggest testing on a small section first.
I’ve been thinking that too but at the same time I’m a little skeptical and would hate for the weathering to get messed up some how when cleaning the layout.As fine as the powder is I would think it would stay in place on its own.
Might just have to wear the overalls anyways!You are probably fine unless: 1) the powders have metallic content, which might be pulled up and into your locomotive electronics (motor, DCC controllers, etc). See if a nearby hand-held magnet picks them up; or 2)Whether they stick to your fingertips if you touch the ballast when re-railing cars and then rub them on light clothing. They probably wouldn't cause any more trouble there than would dust or dirt...but you might also find yourself doing a lot of laundry. In which case: wear dark clothing when running trains. Perhaps railroader's overalls....
What’s A & I?Although it's not weathering powder and I'm not sure of the effect you are looking for, something I do is put A&I on high travel areas which darkens the ballast. I put it on with an eye dropper.
Ahh okay. That’s what I thought you meant by A & I but wasn’t sure 100%. I used both weathering powders and the A & I mixture to weather the ballast to add variety.I use isopropyl alcohol and India ink. The alcohol let's it soak into the ballast.
