So my wife gave me the go ahead to take over the utility room to build my layout. I started with a 4x8 layout a few months ago and have learned alot and also found alot of things I don't like about it.
I'm planning to model a more modern railway and diesels. So no steam. I would like something that 1-3 people can operate using DCC. I tried to give it enough operations interest but with younger kids and also visitors I wanted to have at least one loop so I could just kick off a train and let it go. However the operations part is what I have liked to do with my current 4x8 even with it's limitations. I don't really have a location in mind at all for the layout either.
The table size is 10 1/2 by 7 1/2 which pretty much maximizes my space I think. I have a double deck staging which is accessible since it is against the aisle. My plan was to run a train into staging and then manually move the engine to the other end in between sessions to turn it around to come back out. Currently there is 7" of elevation between the decks does this seem reasonable to fiddle ?
I wanted to have a place where I could put in a lift out section so I don't have to duckunder all the time, I'm still hoping I can do that on the right side of the layout but it is fairly tight at the moment.
I have redrawn the yard many times based on ideas in this forum and still not sure that I have enough track length to handle a reasonable length train. My staging tracks are probably longer then they need to be based on my current yard limitations.
To try to get more space in the yard I put in a peco double slip switch. What is the reliability of those is that going to be a problem. To date I have only used atlas track/switches but alot of people on here say peco are better and they seem to look nicer. Also the 2 back to back curved switches are shinohara #6's that I already have so wanted to use them to get more A/D track space.
The first picture shows the lower staging which allows me to have trains enter from east or west. The second picture shows the upper staging which can only enter from one direction. The last picture shows a drawing of the room with the location of the layout.
Any comments are appreciated. Not being an expert gets a bit scary thinking about building a larger layout only to find something drastically wrong with it that impacts the joy in running trains (like my current layout).
