ECos 50200 not reading WoW decoder
meng
Hi,
I recently set up an ECos 50200 and it won't recognize a WOW decoder I installed. I know the locomotive works, it operated on a different layout, and it appears that there is power on my layout as the resting sounds and lights are currently working. Any idea what I should do?
Thanks!
Matt
Did you program the address in the engine with your ECoS or another system ? I've had a few occasions where I programmed the address on a Lenz system and my ECoS wouldn't acknowledge it. Reprogrammed the address with the ECoS and it worked fine.
Still have no idea what the difference is ....
Mark.
