Midnught Special
Ok I just got one of my cheap locos fitted with DCC, and before anyone says any thing about "spending more on the DCC then the locos are worth" please leave that out of the thread
anyways I got the Queen Elizabeth fitted with a DN163 (thats what the paper says) how ever when running it on my DC set up (least until I get my DC controler) it behaves a bit erraticially, when its set up with factory settings and values it runs fine, like a bat out of heck.
how ever when I try to adjust the speed curve to limit the unit to a specific speed cap it behaves a bit erraticially, mainly seems to be jerky. im trying to set the engine to cap at speed step 128 at 100 (im assumeing its scale MPH) for some what of a proto realistic top speed.
anyways what im trying to figure out is how can I do this, I am using JMRI so when I set the speed table up I use one of the graduating curves (I forget which button name it is but its like the first or second to the far left) and then write the values to the decoder, and then when testing on the layout it acts like it wants to die, also when I ran it flat out (with the configured speed steps to cap at a realistic top speed) it started real slow like I wanted then it just stopped tripped my DC circuit breaker then after it reset (the breaker) the engine was re tried at full it did the same except the second time it slowly started, stopped then two seconds later shot off like a bat out of heck again.
so I am wondering whats going on here, do I have a problematic decoder or is something else going on? the decoder that is being used is rated for the motor type in the engine so it should be working with out issues there, I have no lighting at all on this loco and I just needed basic control of the loco in question.
Thanks for the help!
