catnippertom
That Oregon Guy
I recently snatched this SP F7a unit from my local train store. A few weeks prior I bought the b unit not knowing they had the A unit so once I saw it, I had to snag it. It was $25 which I thought was a good deal for what I assumed was a running loco. The loco did indeed run but only for a moment. I have been watching a lot of SMT Mainline on Youtube so I figured I would be able to repair it easily with some cleaning or something. I decided to dive into it while changing out the couplers to Kadees. Turned out the loco had some running issues. As seen in the pictures, what I assume is the driveline, disconnects after only running for a short amount of time. The front trucks still move and pick up power and the motor still spins fine but the connection to the rear is broken. I am not sure what I should do with it so I decided to consult the forum. I thought about using some super glue or something similar to lock it onto the motor output but I didn't want to do that unless that was the only fix. If anyone has any other better ideas than glue lmk.
