I am attempting to create a small rise in elevation, 1/2 in, for the part of the track at one end of my layout and also a small river that requires a drop in elevation for the river bottom. Basically my layout is a double oval with some turnouts. I know most of you are fond of foam and I've read a lot about how you work with it.
BUT would it just be easier to use the technique where you trace the elevated section of the track, cut it like a flap and support it with braces to achieve the heights I need. And then do the same with the small river but drop it down? thanks,
