hamltnblue
Hello All
I have an ITT HQ series Sound module for my grade crossing. WWW.ittproducts.com
I also have the Trainspeed Flashmaster. WWW.trainspeed.com
Has anyone hooked these together and if so what would be the connections.
Here's the outputs of the flashmaster
Flashmaster
1 Light 1 Connect to one of the two light wires from the flashers
2 Light 2 Connect to the other light wire from the flashers
3 +5V Available for incandescent lights
4 COM_RES Connect to the common wire from the flashers if your
flashers do not have resistors installed
5 COM Connect to the common wire from the flashers if your
flashers have resistors installed
6 GND GND (0V) connection
7 Cascade Input to master unit when cascading two units together for
more then two track operation
8 BELL_neg External bell unit trigger – low going signal
9 BELL_pos External bell unit trigger – high going signal
10 XOVER Crossover input (see advanced options)
Thanks
Flashmaster
Thanks
